Displays the pause control frames received or transmitted.
| rx-pauses | Displays pause control frames received. |
| tx-pauses | Displays pause control frames transmitted. |
| no-refresh | Specifies a static snapshot of data. |
| refresh | Specifies a continuous refresh of output. |
By default, the pause control frames received are displayed.
If you do not specify a port number or range of ports, the system displays information for all ports.
If you specify the no-refresh parameter, the system displays a snapshot of the data at the time you issue the command. If you do not specify the no-refresh option, the display refreshes until you press [ESC].
The following example displays the flow control for ports 1, 5, and 9.
# show ports 1,5,9 flow-control
Flow Control Frame Monitor Sat Aug 18 19:35:12 2012
Port Pause PFC0 PFC1 PFC2 PFC3 PFC4 PFC5 PFC6 PFC7
Rcvs Rcvs Rcvs Rcvs Rcvs Rcvs Rcvs Rcvs Rcvs
1 - - - - 1234567 1234567 - 1234567 -
5 - - - - 1234567 1234567 - 1234567 -
16:104 1234567 - - - - - - - -
">" Name truncated, "-" rx-pause not enabled, "." Counter not available
Spacebar->Toggle screen 0->Clear counters U->Pageup D->Pagedown ESC->exit
Use the [spacebar] to toggle this real-time display for all ports from received frames to transmitted frames, in that order.
This command was first available in ExtremeXOS 15.6.2.
The refresh keyword was added in ExtremeXOS 16.1.
This command is supported on all platforms.
